I think when you do this, some of the readings don't change. For example, the engine coolant temperature doesn't seem to go up as you drive.
Another small heater point is that the temperature control seems to work even with the rest of the system OFF, so if it's really cold out you can crank up the temperature and then turn off the system and get some heat just from what wind blows through the heater...
