Insight Central: Honda Insight Forum - View Single Post - charging the 12V battery with no IMA
Old 12-14-2007, 08:13 PM   #25 (permalink)
IamIan
IamIan's Avatar
Originally Posted by james
Isn't the real problem that to get anything other that the stock capacity out of the IMA, you'd have to replace (or figure out how to reprogram) a lot of the control electronics? It seems like the BCM must have min/max Ah values hard-coded in it.
for the ideal system you are correct....
But as Mike Shows on his website... and others have done .... you can use a second High Voltage battery in the insight to augment the stock one.... thus giving yourself additional electrical energy storage...
The stock battery still handles the big current hits like 100Amps out and 50 Amps in ... and the secondary battery can offset the need for ICE function to replace the energy stored in the stock batteries....
If your second battery is say putting out 20 Amps that means when the car needs 100 Amps the stock batteries are only getting used for 80 Amps and the secondary makes up the other 20, which allows for more assist.... when the Insight gets to level ground or going down hill the secondary battery can continue to supply 20 amps which will act as additional regeneration without the need for the regen load on the ICE, which reduce the FE hit of regen...
The Additional source of Electrical energy that does not have to come from the Insights ICE / gasoline allows for the 100+ MPG numbers that Mike was referring to.... at least as long as the secondary battery can supply the additional boost current.... which is why the Li batteries are nice for the energy per pound that they have.
The boost or secondary battery is no easy thing to do ... and has great potential to void your warranty .... and the amounts of electricity being used can kill you.... so proper care needs to be exercised... It should only be done carefully and safely by people who know what they are doing... If you need to be told how to do it... you probably are not qualified to do it... if you want to... go out and learn and get qualified .... or give support and wait for a refined finished consumer level version to be available... if that ever happens.
But it is easier and safer to add a secondary booster battery than to completely redo / reprogram / rebuild the insights control systems to allow for the safe use of a single higher capacity battery pack.... even if the rebuild would the the "ideal" way to do it.
00-MT-I1
