Insight Central: Honda Insight Forum - View Single Post - New MIMA Thread
Thread: New MIMA Thread
Old 03-06-2008, 07:05 PM   #16 (permalink)
IamIan
IamIan's Avatar
Default re: New MIMA Thread
Originally Posted by gpsman1
I am going to purchase an Insight very soon.
So I will probably want MIMA in the near future ( maybe be 9th or 10th on the wait list??? ).
To Mike the inventor... I am buying this car because I perceive it to be one of the simplest hybrid models to hack and modify. Would you agree with this assumption? Also, due to its aluminum shell and light weight, I feel down the road, it would be one of the best chassis for possible all EV conversion, do you agree?
Lastly, would you find MIMA to be an advantage down the road, if I wish to custom build my own battery pack?
Just curious, but it sounds very promising.
My other car is a FEH and I get about 54 MPG in city driving, in mild weather in that 4,000 pound "brick".
But the Fords look like much more work to "hack".
Thanks!
Hopefully I'll be in the club in a couple of weeks.
-John
I won't speak for Mike or those who also worked on the development of MIMA But this is my 2 bits.
Of course any Hack or Mod risks voiding warranty and killing you or your car.
I think Insight is the easiest HEV to hack and for after market modifications... there are fewer of them so don't expect as much pre-made modifications as other HEVs might get.
I almost got a EV conversion of my pre-Insight car when it died... a 1990 Chevy Cavalier ... but in the end at the time what I could afford for the EV conversion would not have met my driving needs at the time... so I got the Insight instead... which I think is a great platform for conversion to EV... there are very very few cars you can buy that can beat the Insight for Low weight and aerodynamics...
My plan is more of a PHEV conversion.
MIMA was great because it gave me the control of the IMA motor that I wanted to have.
I have been planning and studying to do a small high voltage booster battery to make my Insight a PHEV... I live in an apartment right now so any battery I want to plug in I have to be able to remove from the car and carry into the apartment to charge up.... this greatly limits allot of my options... Lead Acid is way to heavy... NiMH is doable... I estimate the removable PHEV booster battery will weigh around 60 Pounds... Li-Ion would be about 3 to 4 times as much money as NiMH but would reduce that removable PHEV booster battery down to under 40 pounds...
I look forward to using my MIMA and the second battery to offset more of the gasoline I would have used to go the same distance.
After the PHEV booster battery is done I plan to continue to make more mods for my insight that will push it more and more into EV range and allow even more electric priority operation with the help of MIMA.
Even if I end up doing a full EV conversion I like my insight for the vehicle... I like the included 10kW IMA motor and the motor controller with regenerative braking ... the included DC-DC module.... lots and lots of nice stuff.
00-MT-I1
