Thread: Phev Insight
Old 12-18-2008, 12:16 AM   #102 (permalink)
Insightful Trekker
Default Re: Phev Insight
Originally Posted by IamIan
I doubt the Insight ever charges to 100% SoC ... and unless it does it would never see the voltage blip at the end of charging.... even if it did... it is only ~3mV... that is a tiny blip... and each cell would probably not hit that point at the same time.
Good point Ian
I guess my assumptions about max voltage causing the charge termination after a reset could be wrong?
Remember Mike, Peter's changed battery chemistry. So given the voltage differences you and he are now finding is seems that voltage is _not_ a BCM logic function afterall...?
(Edit: Nevermind, See Peter's subsequent post immediately below)
02 5spd, 130k+Miles
