Thread: Phev Insight
Old 01-02-2009, 09:12 AM   #140 (permalink)
retepsnikrep
Default Re: Phev Insight
Thanks for that Roger I do fell pretty pleased at the minute!
First Findings
45 Mile trip today 112mpg (UK) compared to my normal for this time of year abour 93mpg. Lot's to learn.
First thing I learnt was MIMA is vital, if you can't turn off forced charge and command extra power then it's a no go IMO. Well done MIke
OK How did BCM react? Well after topping it off last night via mains charger, it did not do a positive recal this morning. To be fair it was showing about 75% on dash gauge anyway. I started the journey with cells pretty cold at about 2C I had no autostop for entire journey due to cold air temp. Engine took quite a bit longer to warm up as the power was being offset by extra assist I altered my driving style from my normal peg instant FCD at 100mpg to peg it at 125mpg.
Today I used as much assist as was reqd to maintain 125mpg at 40-45mph over my normal commute, traffic in town at end of journey was horrible, so that brought it down to the 112mpg. Initially charge fell away on gauge at about the rate I would expect for normal IMA use at this level, and it was def counting ah IMO until it got to three bars. There it sat for the rest of the journey It appeared to be waiting for a nimh cell to go low which would have then triggered the gauge to fall to zero and stop assist etc. But as the cells didn't go low it just allowed assist ad infinitum. It was trying to force charge but that was disabled. It did not trigger an error, but just sat at three bars. Assist seemed to be limited to about 50% which was not a bad thing and may have been due to the battery temp or the indicated soc. Anyway it prevented me from abusing my new cells with some 100A assist
Battery temp at end of test was about 10C but car had been heated during hour long journey as well. No hot spots in pack when checked with infra red thermometer. Battery resting voltage was 165V at end of trip. 165/50 = 3.3v which is about the nominal voltage for these li-fepo4 cells. I don't know how many ah I used, but car is now on charge and I will know the kwh consumed from the mains in a couple of hours.
For the trip I disabled regen unless commanded with joystick, so it never charged except when braking/slowing down. I used manual assist and regen for this first test, sometimes when on a decent straight I put on one led of assist and then clicked the joystick to maintain it.
If one led fully lit is about 25A of assist that seems reasonable for the cells, which should be able to supply that load for about 90 minutes.
Also no High or Low Cell voltage alarms during trip even under hard 50A regen and BMS seems to be working fine
Sadly I'm back at work tomorrow and voltmeter hasn't arrived yet so that will have to wait.
