Majestic honda shows the whole PC board with switches for $23.
That's probably the best way to go if wiggling it doesn't free it up. The board just clips in with a small electrical connector. It would be kind of small to solder and (my opinion) well worth $23. Had I known, I would have replaced mine instead of replacing the cluster.
Getting to it is very easy.
1. Remove the 4 nuts that hold up the steering column and let it drop to the floor.
2. With a pair of pliers, pull out the small cover that hides a bolt in the center vent outlets. (You have to pull on one of the vanes next to the vent in the center of the dashboard.)
3. Remove that bolt and the entire cluster trim surround pulls off.
4. Remove 4 bolts and pull out the cluster.
5. Release the 6 catches around the back of the cluster plus the one in the center.
6. Now you have access to the board.
20 minute job
