Originally Posted by retepsnikrep
OK
Here is my new schematic for the simplified 7 subpack balancer. It's not quite finished need to spec a few connectors etc.
Peter, given that the pack is 20 sticks, can you come up with a circuit for a 5 charger (4 sticks = 30V each?) system? (just a charger, not a balancer) I want to start wiring in the connections on the relay board side and bring out a (safe) connector with 6 charging leads. I'd like to wire in a main relay disconnect and a fan connect as well.
Plugging in the connector would disable the main relays and turn on the fan.
Actually, this should have been in the grid charger thread.
