Insight Central: Honda Insight Forum - View Single Post - some mods to think about, by a newb..
Old 07-01-2009, 10:37 AM   #1 (permalink)
924guy
924guy's Avatar
Default some mods to think about, by a newb..
hey all,
I'm mulling through the list of things id like to "improve" on the insight, mostly for comfort/convenience at this point, Ill think of more mechanical thing after i know the car better. I did do a search of most of these items, some came up with great info, some didnt come up at all. but being a "car guy" I've always found it helpfull to run my ideas past a group of like minded people, and get feed back.
I should be clear this is all no budjet, or very low budget hand made or modified from pick and pull (salvage yard) parts. So buy this , its only $250.00 isnt really going to register with me. so here it goes:
1. center console with armrest- im thinking a honda civic (95-98 or so) should fit almost perfectly, as they have the center mount ebrake and narrow chassis? I can custom build one out of fiberglass if need be, but theres a better chance of actually getting it done if i can just pull a unit that will work from another car...
2. auto dim mirror- i can pull one from a salvage yard for under $20, im going to try and find one with the compass and temp reading (need the sensor as well) just for the extra cool factor..
3. radio upgrade: Ive already swapped out the door speakers with a set of good ones that came with my civic and i never installed, huge improvement. next up is adding a rear set, thanks to you all i now understand it prewired..good stuff! I have a almost complete car pc , including a 7" touchscreen hi res monitor. i know one of you had an enclosure fabbed up for a double din, and think i will do the same, but for the t/s monitor. im also thinking i can mount the cpu unit where the factory cd changer would go, i just have to check spacing. this will give me integrated gps, wifi, radio,obd2 readings, etc.etc.. but will also require a small amp to drive the speakers, ...
OR... i might just swap out the cassete deck with something slightly more recent from the shelf in my garage.. time for complex installs and fabbing up panels is tough to come by these days..
4. definately need to add an AFM gauge if i dont go with the car pc option..
5. id like to add some LED bulbs, but searching the posts, im unclear as to which ones work with out issue, seems a crap shoot. I will add some interior LED courtesy lighting, but nothing fancy, not looking for a bling factor, just utility..
6. TPMS- i think a tire pressure monitoring system is a great upgrade for the insight, though there are issues with the in tire sensors yeilding to moisture giving them a short life expectancy, i need to research this more.
7. FOG Lights are a must.. amber projector fogs are definitely on my must have list... just need to find a set that compliments the car, and are high functioning and not $300.00, more difficult than it should be i think...
8. just for kicks, i think ill add some hood strips and replace the decals. ive got my own vinyl cutter so i can play a bit...
9. window tint- also a must here in sunny florida, the window lines seem pretty simple, so i think i can do a decent job of that myself..
So thats a good start for me, ive got other ideas for the engine , but those are later on.. but i do want to look at the specs of the 1.0 and see what improvements can be made that yield both more power and efficiency. think intake and exhaust mods, and some other tuning tricks...
Eric...
No normal cars for me! Ill be back when i get the CRZ...
Y2K Insight-New Formula RedSold!
1999 Isuzu VehiCross-ebony black SOLD!
1978 Porsche 924-building into racer. soon to be daily driver.
1982 Porsche 931- building into road endurance racer!
project on indefinite hold.
924guy is offline   Reply With Quote
