Thread: Phev Insight
Old 07-04-2009, 06:42 PM   #263 (permalink)
IamIan
IamIan's Avatar
Originally Posted by crx_rogus View Post
I understand about series vs. parallel (I've monkeyed with electronics since I was wee), but I didn't think there would be that big a dV across a pair of subpacks that had just spent at least the last several hours or so balancing each other in a no-load situation. Now I know.
As long as the two packs are always connected to each other then sure they should have the same Voltage as any 2 parallel batteries would.... but not the same current.
If you charge up the secondary battery and then connect it to the OEM battery now you have a difference and will have a surge of amps... and like I showed ... the worst case for the two batteries by themselves would be a surge of ~66 Amps... probably wouldn't last very long ... but it is a worst case to plan for.
If they stay connected when you start up the car and drive off... they are still connected when the IMA system asks for ~100 Amps of assist... so like any set of batteries in parallel the current might not be equally distributed... between the two... and your secondary battery could easily end up being asked for ~50+ Amps.
Just think about it like this... your secondary battery that is connected in parallel to the OEM battery will see the same dV that the OEM battery sees... and that causes the OEM battery to put out up to ~100 Amps when it is by itself ... if your secondary battery has equal Ohms and SoC as the OEM battery than it will see 1/2 of the ~100 Amps ... or ~50 Amps come from the secondary battery and the other ~50 Amps come from the OEM battery... if the secondary battery has less Ohms or a Different SoC... it might end up sending more than ~50 Amps... If the secondary battery has more Ohms or a different SoC it might end up sending less than ~50 Amps.
Unless you have some type of device to limit the current that will flow between the secondary and the OEM battery.
That's exactly why I assumed long strings of battery cells of any type are a bad idea, not realizing NiMHs ever so conveniently short themselves out of the way.
Series connections are needed for the higher voltages ... you get the same amount of Watts from 200V at 1 Amp... as you do at 20V at 10 Amps... but losses and heat from resistance are not driven by the voltage ... Resistance losses come from R*I^2 ... so while 200V & 1 Amp = 200 Watts = 20V & 10 Amps... for 1 Ohm the 1 Amp produces 1 Watt of waste heat due to resistance ... but the same 1 Ohm for the 10 Amps produces 100 Watts of waste heat due to resistance.... so the same amount of power to do work 200Watts is made either way... but by having higher voltages you greatly reduce the losses due to resistance.
In order to increase the voltage from a battery pack above the 2V per cell PbA ... or the 3.6V per cell of Li ... you have to connect them in series.
You can try to use a DC-DC device ... but even at 95% efficiency a DC-DC device would loose ~10 Watts from a 200 Watt load... plus any of the resistance losses in order to get the amps and volts into the DC-DC in the first place ... so it still ends up being much more efficient to run multiple cells in series to get higher voltages.
NiMH only short themselves toward 0 Ohms at cell failure ... not cell reversal.
and thus probably avoid having a $40k+ car do the same thing Sony and Dell laptop computers did awhile back... have their lithium-based battery packs burst into bright, smoky "thermal runaway" states taking the value of whatever they're in with them.
yup.
It would be nice for the Insight to have something besides a way to gradually de-EV upon noticing subpack thermal issues, something to help counteract any developing out-of-balance issues.
People are working on it...
See thread: grid charger/balancer
Hmmm... NiMH cell failure = shorting itself out of the way, yet cell reversal can lead can eventually lead to exciting things possibly involving release of a cell's magic smoke (does it eventually short itself, or keep its radical overvolt condition?)...
Over voltage comes from over charging ... and the BCM is supposed to prevent that.... if it fails to do so... NiMH will tolerate some over charging ... better than Li ... but still limited.
Eventually if continued to be over charged further and further ... just like PbA ... NiMH will get very very hot ... then start to vent electrolyte as a gas that contains a mix of Hydrogen and Oxygen gas.
Venting Hydrogen and Oxygen gas into a hot area containing electrical current flow ... is asking for problems.... just like it is with PbA.
but all of that is just from over charging...
Over discharging is where you get voltage reversal.... this is kind of like putting a 0% SoC battery in a battery charger backwards ( reversing the polarity and forcing the charge anyway ) ... in a cell reversal you are forcing the + button side terminal of the battery to be a - terminal ... and you are forcing the - Flat side terminal of the battery to be a + terminal... you are just like the term sounds like ... you are reversing the voltage of the cell.
Cell Reversal will expedite a cells death into cell failure ... but NiMH is tollerant enough of cell reversal that it won't die fast enough ... the cell in reversal will end up being a liability event long before it ends up failing.
One issue with Insight 120S packs then is, I'm guessing, overcharging leads to relatively benign cell failure while chronic discharging getting out of hand can lead to catastrophic cell reversal.
Actually the BCM is a bit smarter than that... in order to prolong NiMH service life the OEM battery pack is not charged up to 100% SoC ... and it is not discharged down to 0% SoC... instead the BCM avoids the ends... and keeps the SoC closer to the middle... in this way it extends a NiMH battery cycle life from a few hundred cycles ... to many thousands of cycles.... which is needed for vehicular service considerations.
If the BCM sees / calculates that one of the cells is getting very near 100% SoC... it stops charging the whole pack before it gets there... if the BCM sees / calculates that one of the cells is getting very near 0% SoC ... it stops discharging the whole pack.
In order to try and avoid over charging or over discharging it instead reduces the effective usable capacity of the battery pack.
If the battery pack gets to low in BCM usable capacity it lights up the IMA error code light ... to indicate a problem ... Honda will then recommend you replace the whole battery pack.
Because the Ohms vary with temperature as shown before ... and because not all of the 120 cells are the same temperature under use... eventually some of the cells reach a different SoC than other cells ... even if they have not effectively lost any capacity at all.... but the OEM BCM was not built to rebalance the SoC... instead it just keeps on restricting the usable capacity.
Which is what lead to the IMA battery rebuilding service:
Hybrid-Battery-Repair
I'm also getting the impression that the Tesla Roadster among approaching others must have some astoundingly sophisticated BMS hardware and software, with a significant cost of the vehicle development just going into BMS development. A Roadster stranded with a flaming battery pack would produce unproductive PR, especially in the courts. My multicharger alone has all sorts of warnings about choosing the correct Lix setting stemming from the 0.1V cell potential difference between LiIo and LiPo.
Yup... lots of time , effort , and $.
But the #1 issue most people end up having with EVs is the range per charge / charge times... both of which are things that current modern Li have significant advantages in ... as long as you include a proper BMS.... and have a large enough budget for them.
PbA works well for my home's hobby-grade solar-recharged 12V subsystem (powering the 3 D->C cycle slow refreshing of the spare pack's subpacks effortlessly), and has reliably and safely and without stink (except near the recharging racks) moved countless tons of paper, ink and anything else imaginable for at least a couple decades at work, but getting folks to remember to recharge the battery, not the drive terminals, on some of the smaller equipment is always a challenge.
Yup... there is no one battery... they all including PbA continue to have pros and cons ... and each application will have needs that determine which is the best fit.
I've been gradually reading V2G-101, learning how V2G-enabled versions of cars like the (apparently truly heading towards real production) Chevy Volt (and current Tesla Roadster) will (/can) earn their owners / leasees up to about half their new cars' monthly payments back via buffer service micro-contracts with the local grid utility. But first, we need a smart grid. Flywheel, hydraulic and pneumatic -based hybrids also appear viable. There is indeed alot of really fascinating stuff going on out there, mostly off-topic for this thread.
Agreed.
00-MT-I1
