Originally Posted by Hybrid-Battery-Repair
A few numbers for you:
At 35 amps, a battery gives up about 4 ah in seven minutes.
At 10 amps, it takes about 30 minutes to put that charge back.
At 25 amps, a battery gives up about 4 ah in eleven minutes.
And, your point is???? I am trying to keep from overheating the battery at 200ma to 250ma. charge and at 4 amps the entire battery, taken one stick at a time, can be discharged in a day. The math is simple.
