first crazy thought that came to mind was making a new cage for the the lifepo4 cells
of course that depends of how much spare space you have to play with, the new cage of course had to use the bolts that are allready are there, but if the wheight of the pack is the same or close to that should not be a problem
making another board that interfaces with the RS485, will that make the belive the pack is X-number bigger? or will it just correct the display?
regarding replace the BCM complete i stand with one foot on yes and the other on no.. normal i like everything as close to as it left the factory... but i'm open to idea's
btw. i'm close to have saved up 1/3 for an insight
