Insight Central: Honda Insight Forum - View Single Post - Throttle circuits
Old 08-14-2009, 10:59 AM   #6 (permalink)
joecvt
joecvt's Avatar
Originally Posted by Expertfabricator View Post
The only thing is if you switch it while the engine is running its possible to throw a check engine light. Would have to try it and see. If the check engine light does come on you can shut the car off ,pull the ecm fuse wait a few minutes. Then replace the fuse and restart the car code or check engine light will be gone.
As long as the TPS voltage remains in a valid range, you will NOT get a check engine light. Disabling ground should bring the TPS voltage back to normal spec. Doing it live (while driving) should be no different than quickly moving your foot on the gas pedal.
I have some long term experience with the TPS voltage as I have made a special circuit for the CVT transmission that modifies the TPS voltage going to the Transmission Control Module so that under light engine load (using MAP sensor voltage) the TPS voltage is reduced a bit so the CVT stays in a better ratio for better MPG....Under a more heavy load, the voltage goes back to near normal levels. This allows the ratio not to change (causing a loss in MPG) when going up very short slight incline hills.
Since you are not removing the voltage by flipping the switch (only modifying the voltage) and the voltage will remain in a valid range, I guarantee the ECM will not trigger a check engine light
No other mods performed yet
2003 CVT Blue Insight
Low Speed Auto Stop (LSAS)
Not registered yet
