I'll see how it works for the time being. I appreciate all the comments. I got an ABS black nice case for it today which seems to fit those 4 psu's i'm using quite well. I'm going to add a thermal fuse inside case on input to go off at 84C and a 1amp fuse on output. Probably use flying leads in/out for these first two examples I'm building. HV out connector will be fitted with shrouded plug. Insight will be fitted with shrouded socket and diodes near bat terminals. Might extend one of the 4 psu leds to protrude through case as mains indicator.
