Old 08-17-2009, 01:45 PM   #170 (permalink)
3-Wheeler
3-Wheeler's Avatar
Peter,
Let me know how your thermal fuse works out for you.
We have numerous environmental test chambers at work, and some of the older one's used to have thermal fuses that open circuit at 200C or so by design.
We ended up having to remove them and use another method to detect over temperature, since the thermal fuses did not prove to be very reliable. Even the chamber manufacturer no longer uses them due to their instability.
Hope this helps.
Jim.
