Insight Central: Honda Insight Forum - View Single Post - Often-logged complaints on 2010 Prius....
Old 08-20-2009, 08:29 PM   #1 (permalink)
easygoer13
Default Often-logged complaints on 2010 Prius....
This taken from a thread today on the PriusChat forum:
Summary of problems reported on Prius 2010
List of problems reported on the Prius 2010
Problem: Red arrow in energy monitor hard to see in daylight
Description: Fix for difficulty seeing red arrows on Energy Monitor Screen in daylight (2010 Prius II)?
Solution: Pending
Problem: Car computer overestimates MPG
Description: 2010 calculated vs. computer MPG - Please post your results
Solution: Pending (Toyota has been made aware of the problem)
Problem: Air Conditioning display is cloudy/blurry
Description: Cloudy/Blurry AC screen?
Solution: Pending
Problem: Cargo net panel separation
Description: 2010 Cargo Net issues and resolution (panel separation)
Solution: Toyota has suspended sales of the nets while they work on a solution. Some have found temporary fixes as detailed in the link above.
Problem: Delay in answering calls with Nav and Bluetooth
Description: Delay in answering phone w/Nav
Solution: Pending
Problem: Satellite radio signal is weak
Description: 2010 Prius - Satellite Radio Signal Weak
Solution: Pending
Problem: Satellite radio display is truncated to 16 characters
Description: Satellite Radio Character Length
Solution: Pending
Problem: Ghost image on speed display
Description: Double Vision on Speed Display
Solution: Pending, although some have observed that the intensity of the ghosting effect depends on the driver's head position.
Problem: Brakes grabbing in reverse
Description: braking in reverse
Solution: Pending, although some have found ways to avoid it, and others claim the problem goes away after a few weeks.
easygoer13 is offline   Reply With Quote
