Old 09-19-2009, 08:08 AM   #206 (permalink)
crx_rogus
Default Charger ventilation
Peter -
You're including decent ventilation for them, aren't you? I tuck my charger assembly in between the IMA power station housing and the fender on the passenger side and find it runs much cooler with a little CPU fan blowing air past the works. Simple unobstructed convection cooling would probably work too, given enough open area, something your house-stored unit could take advantage of via a large enough vented box. I have mine in a closed-in area to help secure it, with the fan's air exiting out the back (the unit sticks out some past the power station housing).
I'm using a 6V power supply for the battery pack fan (in parallel with the charger's CPU fan), and a Kill-A-Watt to help track watt-hours in (it uses about 1 watt doing nothing, 3 watts just powering the two fans, 65 watts charging... the volt-amps are higher than that though). It still uses full power at about 165V to the pack, 167V charger-limited (and 350mA current-limited). I also have a remote thermometer sensor at the pack's fan so I know that 45 minutes into charging the pack exhaust air is 3 degrees F warmer than interior ambient, partly from charger heat.
I plug it in to my backyard's dawn-to-dusk timer-controlled water fountain power source so I know it'll shut off when it gets dark.
It added about 10mpg to get in the 70s for several miles before settling back down into the mid to high 60s by 14 miles, still over the 60 - 63 mpg I normally get, giving a positive recal about 5 miles into the trip. It basically eliminates SOC maintenance issues; no more always using extra gas via background charging and extra rpm to get the SOC back up if it falls significantly somehow. I make sure not to have it charging for more hours than would be needed to keep the SOC in the safe zone.
I did however manage to connect the fan power supply leads backwards initially, which has led to a bit of an adventure... A blocking diode on each wire or disconnecting it completely doesn't even restore normal in-driving fan voltages now, so while it's easy to make sure the pack charger leads are the correct polarity it is equally important to be as careful with fan lead polarity.
My 100 chargers are now enroute from China! I shall start building them up as soon as they arrive. ...
Regards,
Roger
2000 silver 5spd #4047
Silver 2000 5spd Insight
218,000 mi.
55 - 76 mpg
rogerspace.org/2000insight.html
Action without philosophy is a lethal weapon; philosophy without action is useless.
- Soichiro Honda
