Insight Central: Honda Insight Forum - View Single Post - hawk hps front pads
Old 09-26-2009, 08:18 PM   #8 (permalink)
gsfent
Originally Posted by crxgator View Post
the handbrake adjuster is in the cabin. you need to take off the panel that is on the handbrake itself. then you will see a 12 mm nut on the ebrake, you tighten that nut.
I understand that will adjust the height of the handbrake, but aren't there adjusters in the rear wheels that adjust the handbrake and actually help with the foot brake by tightening it up? The ones that adjust the brake when you go in reverse?
REgards,
Jerry
