Old 10-13-2009, 08:07 PM   #218 (permalink)
crx_rogus
Default Charger output voltage
I've been making some changes to my grid chargers and they now uses 3 x 48v psu's adjusted to 42V and one of Mike's 0-48v 350ma Constant Current power supplies. This gives a 174v maximum output. ...
Maybe my power supplies are on the odd side, but with the volt adjustments minimized the whole works returned 167 volts, right on the money for safe pack charging/rebalancing as-is. I know 42*3+48=174, but there seemed to be extra adjustment room in practice with the units I received. I realize charging/rebalancing as it passes 165V or so would get rather slow, but that would minimize heat buildup. At 162V at least the power supply consumes the same full 63W it does at lower pack voltages.
Regards,
Roger
