Old 10-15-2009, 11:54 AM   #225 (permalink)
Mesuge
Thanks for the details, I'm not sure this equalization focused approach is worth scaling up to say the levels of that Zivan NG3 (.8kW output), which can charge 3.5-4.5kWh (4x parallel packs) in few hours time - as low as 7hrs (T1_5h-T2&T3_onlyfor2h), on the condition of all the safety precautions incl. passive and active cooling system. For Prius, I see the advantage of these MeanWell style cost effective grid charger balancers more in the role of service/maintanance the longevity of batt. pack than for regular PHEV charging application. Because ~100W output doesn't make it practical with these very long charge hours even at shallow %discharge driving cycle. Perhaps at least 4x scaled up version ~400W (roughly 2x slower than Zivan NG3) might be considered as barely practical solution - real charger. Alternatively, set it up as 4x standalone 350mA grid chargers for each OEM sub-pack, but that's 4x cost/work-wirelogy-complexity/space used/failure rate or perhaps not, as some features like the timer could be shared. Altough much safer, this individual type of charging will also to a degree defeat the major advantage of parallel charging function as a balancer.. So, perhaps the Zivan NG3 "rocks" afterall, lol..
Zivan C7 or SX (NiMH) curve issues explained:
http://priuschat.com/forums/gen-ii-p...stol-uk-7.html
Mesuge is offline   Reply With Quote
