Insight Central: Honda Insight Forum - View Single Post - 2009 honda fit sport rims?
Old 11-11-2009, 10:44 AM   #9 (permalink)
Cobb
The 09 sport fit according to tire rack uses 17s. Even if its 16s, you cant use your stock tires.
I found online 1lb to the wheel is like adding 8 inside the car. I have 100 extra lbs at least for the speaker upgrade. Wonder if its removing? Wheel weight effects braking too.
