Insight Central: Honda Insight Forum - View Single Post - Analysing the BCM/MCM Signals
Old 11-21-2009, 01:46 AM   #104 (permalink)
retepsnikrep
That's possible Malcolm, I need to get my wife the excel expert to help me put these files into a better format.
Also in the PTC test, byte six of the $AA packet changes from $00 to $01.
I'll try sending those codes today and see what the car does.
In the High Temp 1 P1568 test where I heated all the temp sensors together
The fifth byte of $AA Changes to $40, then to $48, then $4F
Then byte four changes from $00 to $08
This also occurs in the High Temp 3 test.
So looks like Fourth byte of AA changing to $08 is the P1568 trigger code
and the sixth byte of AA changing to $01 is the P1449 trigger code
EDIT
Confirmed just now with the interceptor sending $08 causes P1568 and $01 causes P1449
