Thank you guys. I will try to get these error codes asap and post them here soon.
BTW, the check engine light is always on, while the IMA light goes on and off.
The IMA light has been off for two days now. Does it make any difference if I read the error codes with the IMA light on or off?
Balance support is for Lithium cells. This is NiMH. You need it to support 12 cells.
The Overloader 1 and the Duratrax ICE support up to 10 cells, right? if so then those are not viable options in my case, right?
