Originally Posted by retepsnikrep
Bloody hell Ron that looks expensive.
That one is an 8 channel unit and costs $15,000 plus freight from Asia. It consumes up to 8,000 watts (and can dissipate 8,000 as well). I can't afford to buy it or upgrade my electrical service for it, so I'm getting a single channel model.
So it is a charger and discharger for upto twelve cells sticks.
How many channels does it have? Will you be using it on MK1 packs?
Do you have any technical information on it?
It is up to 20 volts at up to 50 amps. My single channel unit will be in a 4U case and will charge-discharge-IR test a good quality Gen I stick in about 30 minutes with a cooldown period in between or 15 minutes without cooldown. (A GenII stick would take 45 or 30 minutes.) My current discharge-only testing takes about 15 minutes per stick without charge testing. Also, the IR testing should do away with my one week self-discharge testing and shave a week or more off a repair.
Better tools make a better quality repair. Now I have to see if I need to test at multiple amperages. I know that I can find defects at 30 and 50 amps that I can't find at 10, but the inverse may also be true.
But, I still need to recondition prior to testing, and (Mike are you listening?) I still need to charge up the pack just prior to shipping.
