Old 01-03-2010, 09:08 PM   #242 (permalink)
mrbigh
Default Power Pole connectors
Originally Posted by TRI View Post
I'm watching out for a secure male/female connector set, 250V, 4-pole or more, with a cap on it, attachable only one way. 4-pole because I want to carry the 170V and 12V in the same connector. The female will be put on the charger-side, the male side on the battery-side where I want to have a cap on it as I don't like the idea of having battery voltage lying around open in the trunk. Does anyone know of one. I've been searching for quite long in the electronic parts catalog but couldn't find the right thing.
Or would you better go with two separate plugs?
Or, the other options is a few Anderson design Power Pole connectors.
These are stackable on their side and you can build a 3, 4, 5,6 section connector with different inside contact direction.
An example at ebay for low price
mrbigh is offline   Reply With Quote
