Originally Posted by mrbigh
Or, the other options is a few Anderson design Power Pole connectors.
These are stackable on their side and you can build a 3, 4, 5,6 section connector with different inside contact direction.
Powerwerx.com is a good source for Powerpoles. I use LOTS of them.
What I can't believe is that I actually managed to melt a set of 45 amp Powerpoles while discharging batteries. I'm used to melting and scorching lesser connectors, but Powerpoles? I can't even disconnect them. They're fused together and this was all through 10 gauge wire, not exceeding about 30 amps (but continuous use for months).
