Insight Central: Honda Insight Forum - View Single Post - Building My Trickle / Balance Charger
Old 01-20-2010, 03:32 PM   #1 (permalink)
My02Insight
Default Building My Trickle / Balance Charger
Hey Guys, Just wanted to share my Experience while building my First Charger. I ordered my parts about 3 weeks ago from PeaktoPeak Power Inc, but they were on Backorder so thats why they took so long.
So i messed around with differnt Diodes and Fuse boxes then just came to a simple Solution. I made my Charging system but did not have a box to put it into.
Then I Bought a set of Male and Female Plugs at Radio Shack so i can easily unplug my charger from the car. ( since i have Two Insights i can use the Charger for both of them)
Dug thru my Garage and Found a Fried ECU and I gutted out the insides and used this as a container for my Charger Parts.
My Car ( 2001 Insight MT) was giving my Negative recals any time i would go up to work ( driving up a big hill) and my IMA light would kick in and i would have to reset my IMA System.
I hooked up the Charger to the battery Two Days ago. My Chargers Output was 170VDC @ 350mA.
I unplug it at night ( didnt want to worry about it while sleeping)
Two , Half days of charging my Battery Voltage Finaly Stabalized at 169.5VDC
I took the Car for a 30 Min Drive up and Down some Hills and NO RECALS.
I could feel alot more Torque in the Electric Assist as well. I used full assist to get back home last night to drain my battery so i can CYCLE it again.
Today, Back in the Garage getting a Charge.
IF anyone is interested i can build you this System. You would just have to Connect it to your Car. I use all original MEANWELL supplies ( more $$ then the China ones on different websites) And the Whole system cost me about $140. That include the Shipping from PeaktoPeak, Diodes, New roll of Wire, Male/Female Plug, Adapters, Soldering wire, Electric Tape, Ect....
I will Sell anyone a PreWired System for $200 Plus Shipping. I think $60 is ok for my Time to Build it. However i do not have any Cases for it, so you can be Creative and use your own.
PM me if you are interested and ill send you a Company Invoice.
My02Insight is offline   Reply With Quote
