Old 01-30-2010, 03:04 PM   #255 (permalink)
Mike Dabrowski 2000
Mike Dabrowski 2000's Avatar
I thought it was you that did the test. I suspect that the PTC effect is not linear, and accelerates as the temperature rises. A resistance check with a hot air gun blowing on the devices also shows a strong PTC effect once the part gets hot.
Maybe the soldering iron test did not heat it enough?
I have a civic battery terminal strip, so I will do the same test on that to see if they behave the same.
Mike
Universal grid charger
http://www.99mpg.com/
