I finally got the RS-15-12 supplies yesterday, and will be finishing up the dual stage supply.
I am thinking of connecting the 12V supply to the charger pack negative for the test.
That will allow me to power the voltage detect circuit and relay for turning off the 700ma CC when at nearly full charge from the same supply as the fan.
Since the car will be off, and the fan relays off, I should be able to do it without problems?
I still need to add adigital volt meter, so I can see where the chartge is, and adjust the switch off of the 700ma at different voltages dependiing on the pack voltage.
