Insight Central: Honda Insight Forum - View Single Post - Trans Overhaul
Thread: Trans Overhaul
Old 02-12-2010, 09:28 PM   #15 (permalink)
Highmileage Insighter
Highmileage Insighter's Avatar
Originally Posted by canterburyfred View Post
I'm getting that 2nd gear grinding problem too .... 163,000mi on a 2002 .... has anyone found that this symptom could be explained by anything other than worn syncro? ... transmission oil change or worn clutch possibly? ...
a local shop has offered a used transmission with a lifetime warranty(!) plus new clutch for $2200, which is less than the dealer price for either new or used .... there's also a site called Transmission Planet Remanufactured and Rebuilt Transmissions which sells rebuilts ....
1st and 2nd gear syncho and bearings are the weakest links in the Insight manual trans. Lifetime guarantee? sounds great, as long as they stay in business. $2,200-and if it includes new throw-out bearing, resurfaced or new flywheel, and all the clutch trimmings? New slave cylinder? all new clutch fluid?
Highmileage Insighter is offline   Reply With Quote
