Originally Posted by Buttcheeks Mcgee
The big question still is how do I get through the damned firewall for my amp.
Check the thread about installing a cruise control on an Insight. This part of the instructions might satisfy your needs:
"start by removing the grommet on the heater control cable and running the two four wire connectors that you’ve removed from the wiring harness through this hole from the inside of the car to the engine bay. This is a very frustrating process. Take your time."
Aloha,
Art Isbell
2000 Insight A/C #559
