Insight Central: Honda Insight Forum - View Single Post - Age of sparkplugs??
Old 03-14-2010, 08:34 PM   #4 (permalink)
joecvt
joecvt's Avatar
I would at least remove the single bolt that secures each coil.....Mine were so corroded that I had to drill 2 out of 3 bolts out and the one still in tact wasn't pretty. Swapped them all out with new bolts and antiseize.
I don't see the harm in removing the spark plugs as well and re-coating and torquing since you have such low miles in 10 years.
I only removed the coils to check the letter for the spark plug so I could order them ahead of time. Should be a few more months when I change them.
No other mods performed yet
2003 CVT Blue Insight
Low Speed Auto Stop (LSAS)
Not registered yet
