Insight Central: Honda Insight Forum - View Single Post - Age of sparkplugs??
Old 03-14-2010, 09:35 PM   #5 (permalink)
aisbell
aisbell's Avatar
Originally Posted by joecvt View Post
I would at least remove the single bolt that secures each coil.....Mine were so corroded that I had to drill 2 out of 3 bolts out and the one still in tact wasn't pretty. Swapped them all out with new bolts and antiseize.
Did you consider replacing the bolts with stainless steel bolts?
Aloha,
Art Isbell
2000 Insight A/C #559
