Originally Posted by tomg
My IMA lit up today (2001 Insight, 68,000.0 miles on odometer).
Is this common? Do I need a new Battery pack? Is the car going to blow--up...  ?
The light stays on. My wife says I may need an oil change or some other routeen maintanence (she owns 2005 Prius).
I am going to bring to Honda dealer tomorrow but am looking for some insight into potential expectations.
An IMA light is unlikely to be caused by a routine maintenance problem and more likely to be caused by an IMA system problem. Most common is an IMA battery problem. If the dealer reads a diagnostic trouble code that indicates an IMA battery problem, Honda doesn't do anything but replace the battery. If your Insight hasn't been reconstructed, this replacement should occur under warranty.
Aloha,
Art Isbell
2000 Insight A/C #559
