Originally Posted by JuiceMcGoose
At 600 full charges I guess you are the test example. How many amps does this circuit charge at?
I'm charging 2 battery packs, so my numbers will be a little higher. The beginning portion of the charge starts near 1 amp, but quickly drops to ~600mA ... end charge is near 200 - 300 mA. This is based strictly on voltage of the pack vs voltage of the charger. The cooler months aren't an issue, I can actually leave it plugged in all day. In the summer I need to watch it more closely or the packs can get hot even with the fans running.
Mark
2000 Silver Insight, #5550
