Insight Central: Honda Insight Forum - View Single Post - Insight Record?
Thread: Insight Record?
Old 03-18-2010, 07:04 AM   #21 (permalink)
red1dr
Originally Posted by Jivko57 View Post
I try hard for several months already and also have changed sparkplugs, egr, front tires, have put synthetic oil in the engine and new mt fluid.
From info posted by various people here, it seems to be important for best mpg to:
- use OEM spark plugs, and to match them to the letter stamped next to the spark plug hole on the cylinder head so the electrodes are indexed correctly
- use OEM Bridgestone RE92 tires (anything else seems to cause a 5-10mpg drop in back-to-back testing) and pump them up to at least 44psi (the sidewall rating), preferably more
- use 0W-20 synthetic oil
- use the Honda MT fluid spec'd for the transmission
Yes rain makes a huge difference, probably in tire drag. I move laterally in the lane to try to stay away from the deeper standing water but it isn't always possible.
But it sounds like you're getting there!!
2006 MT
MIMA w/FAS module
various mods to driver
