Insight Central: Honda Insight Forum - View Single Post - Insight Record?
Thread: Insight Record?
Old 03-18-2010, 02:26 PM   #23 (permalink)
red1dr
Originally Posted by JuiceMcGoose View Post
No offence meant red1dr
None taken.
...but there has been way too many MT bearing failures reported on this site.
Really?? Where?? I've been on this site for >3 years (lurking before I joined) and don't recall seeing bearing failures reported, but maybe I missed them. FWIW, I've owned 4 MT Hondas since 1985, zero problems, including >50,000 mi on my Insight with the OEM trans fluid in it.
I almost never shift into 1st while moving (2nd works well for that) and take it easy shifting in general, so maybe I don't notice issues.
In the '80's before Honda MTF came out, Honda spec'd motor oil in the MT. Since I had motorcycles and had oil for them, I'd use 4-stroke motorcycle oil in the Honda MT because motorcycle oils lube the trans and clutch and so have gear lube additives built into them. When Honda MTF came out, I switched to that.
You recommend the friction-modified GM fluid but you're using the non-modified in your Insight??
In any case, it's a good idea to select an MT fluid carefully, as you have done, because some random too-heavy lubricant could decrease mpg. As I understand it, the Insight MT is different from the typical Honda MT.
2006 MT
MIMA w/FAS module
various mods to driver
