Insight Central: Honda Insight Forum - View Single Post - Fuel pump not working
Old 03-25-2010, 10:24 PM   #1 (permalink)
robertsm
Default Fuel pump not working
I recently purchased a 2000 Insight from a junkyard. The car was in an accident in 2002 and has not run since. After reassembling the car and replacing obviously damaged components, it will turn over and even idle briefly if fuel is sprayed into the intake, but the fuel pump is not running. Nothing seemed wrong with the pump when it was out to drain the old gas from the tank.
I have read here that the car has an inertial fuel cutoff feature. How would one determine if this is the problem and how can it be reset? Are there any other likely reasons that the fuel pump would not work?
Thanks
robertsm is offline   Reply With Quote
