Did you have to replace the ECM or install a different one for any reason or did you have to get a key cut (and not have it programmed to the currently installed ECM)? If so, the keycode needed for the engine imobilization system will not match the key and ECM and will not start the car....It will crank but not deliver fuel.
I never heard of anything that will cut off the fuel (until reset) due to inertia. (If there was something like that, any accident that would deploy the airbags would not be able to start the engine as well.)
No other mods performed yet
2003 CVT Blue Insight
Low Speed Auto Stop (LSAS)
Not registered yet
