Old 03-31-2010, 06:01 PM   #359 (permalink)
TRI
TRI's Avatar
Originally Posted by buzzard View Post
Do you experienced people recommend occasional shorter charges from the grid charger to keep up the SOC level (and save fuel since there would presumably be less ABC on the next drive, wouldn't there?). Or should the grid charger be reserved only for longer balancing charges after the new battery begins to age? What would be best to maintain the health of the NiMH pack over time?
My battery pack is weak and I only can drive the car without frustration if I charged it overnight with a grid-charger. Even with a new battery I'd charge it before the next drive after a longer non-use of the car, let's say one week to keep it healthy and balanced.
If you're battery is nearly empty until you arrive at home it gets charged while you're going downhill next time you drive it, no?
Orelse you could charge it with a solar panel.
2000, silver, 5 speed, #0071
TRI is offline   Reply With Quote
