Cooling is not envisaged as a problem but we shall see. The testing these cells have undergone on the ES forum has been upto 600A continious drain until nearly exhausted. Even then they did not heat to dangerous levels. We will only be seeing 100A max for short periods and 50A charge ditto for short periods. Have to see how it all heats up or not as the case may be. Thanks for the solder tips. I'm away shortly for a couple of weeks so i don't expect any real progress for a while.
