Originally Posted by 3-Wheeler
So Mike, any time you program a PIC, is it always done with assembly, or are there times when you use C with an embedded compiler, and then upload to the PIC?
I've only known of just a handful of people to program in assembly, that's why I'm curious.
Jim.
Up until recently, Microchip PICs were programmed almost exclusively in their assembly language or in Parallax's assembly. Microchip's assembly is byte for byte, while Parallax's has some 2->3 byte conversions. The C compilers were very expensive and the chips were so limited that you had to eke out every byte, so C was a luxury that most couldn't afford.
In the late 90's, I designed a DRL controller around a PIC16C54. It had 512 bytes of EPROM for program space and only 25 bytes of RAM (8-bit bytes). You had to get VERY creative with your code to make things fit. C can't generate code as tight as hand-coded assembly.
This message wouldn't have fit in the chip.
