Insight Central: Honda Insight Forum - View Single Post - Download 2000-2006 Insight Service Manual PDF and Others
Old 04-28-2010, 01:08 AM   #23 (permalink)
retepsnikrep
I will upload these to my own webspace as well and provide some simple links when I get back from holiday. I have made them a sticky as well. Thanks to the original uploader. Peter
Edit i've just been looking at a few of these and can see I need to read them all.
The few I have read show that.
1) The current sensors for the battery and motor have a working range of -200 to +200A. My quest for a bit more power may work in the end!
2) The battery detrioration calculations allow a minimum battery capacity of 650mah before a code is set
3) The temp sensors in the battery pack are described in detail with temp/resistance data!
4) They contain data about the construction of the inter BCM/MCM modules serial comms and IMA control that we had to work out the hard way.
To coin a phrase from Mr Spock "Fascinating"
