Thread: Phev Insight
Old 05-04-2010, 01:27 AM   #294 (permalink)
JimIsbell
JimIsbell's Avatar
Not yet. I have two batteries on the bench, one of which I have just refurbished. I was measuring today and I think a second battery will fit forward under the current battery box and the spare tire can be stood up vertically at the back of the storage compartment and will just come up to the bottom of the rear hatch. A small modification of the foam and cloth cover will make it look like a factory install with only a small reduction in the storage capacity on the package shelf.
Then I have to consider making the charger bigger which will require a series current limiter, instead of the CC power supply, to take advantage of the 570ma that the three 48V power supplies are capable of
BUT, I have the MIMA almost finished so I will finish it first.
