Insight Central: Honda Insight Forum - View Single Post - Some calculations related to battery temperature and cooling
Old 06-10-2010, 05:53 PM   #5 (permalink)
MN Driver
Originally Posted by RobertSmalls View Post
If you're using the Insight as a PHEV in the flatlands, where your usage profile is "charge at home, discharge once" with little regen, you'll be interested to know the battery temperature rise will be minimal and the fan will probably never come on.
This is my experience, my entire commute is flat enough to where the only regen that is useful is at stop signs and stop lights, I don't have enough stop signs and stop lights in my commute to recover the amount of power I use with my headlights on the way to work. Outside of the 4 month period of the summer where it is light out when I am leaving to drive home from work in the morning, 100% of my regen opportunities are put towards recovering the DC-DC load and I was pretty much always at 18 or 19 bars this winter/spring.
I have only once had the fan come on, that was when I deliberately cycled the battery down with assist and all the way back up again within the same trip. It charged up faster than I thought it would, the difference between 5 bars and 10 is about the same time in regen as it is 18 to 20 for me.
I won't know whether or not I need the fan while grid charging but if I don't have it, you bet there will be some form of temperature disconnect worked in there but I think I'd rather just run the fan as it is much easier to do and won't cost me pack life if I make a mistake somewhere else and induce some overcharging.
