Insight Central: Honda Insight Forum - View Single Post - Using AC seems to significantly impact MPG.
Old 06-20-2010, 09:22 AM   #3 (permalink)
firsthonda
Originally Posted by buglermcd View Post
Use ECON mode as much as you can. It will cycle the compressor less often. You'll take less of a mpg hit, but you may be a tad hotter.
I do use Econ 99+% of the time. Maybe I need to turn the AC temp up? I typically run it between 65-68 degrees F.
