Old 06-22-2010, 08:38 AM   #531 (permalink)
Mike Dabrowski 2000
Mike Dabrowski 2000's Avatar
Ok, you are using the caps capacitive reactance to limit the current on the ac side. That works.
The LED and fixed supplies is a bit simpler but I can see that what you have should work well.
I like the way you use a magic marker for your front panel graphics, I did the same on the big charger.
I built the PTC circuit onto a perfboard last night,and will finish connecting the relay and circuit to the big charger after my morning e-mail check.
Ron is coming up, to pick it up as I write this, so we will be testing it on a spare Insight pack.
Will snap a few photos of the test.
