Insight Central: Honda Insight Forum - View Single Post - DIY: How to change fuel pump / Fuel Guage Sender
Old 07-11-2010, 04:18 PM   #5 (permalink)
Rush
Premium Member
Great Photos and Details... I had pack rats that chewed up a rubber hose at the top of the fuel tank/sender unit, starting leaking gas... so I took it to Honda. They said they had to lower the fuel tank to access the $1.25 piece, cost $300 for their time. Now if it happens again I will know how to do it. Thanks a lot!
Re Hitech comment about the IMA fan vent - What 02Insight means is to remove the Fan Intake, the fan actually vents back into the IMA battery area and then into the Tire well area via holes in the IMA Battery area cage.
Rush
#2 - 2000 Silver #4095, 185k Miles, 62 LMPG, OBDIIC&C by Peter, GCIM1 by Mike on bat pack
www.TucsonEV.com
Tucson AZ
