Originally Posted by MN Driver
Mike, I'm interested in doing this but am wary about running pack wiring to the cabin, if I put a .5amp fuse in line with wires going up to the drivers seat area, would this cause any voltage drop without load through the wiring?...
MN Driver,
Just use a voltage divider to lower the voltage to something you're more comfortable with.
I made a patch cord with a 10:1 voltage divider and the voltmeter reads 16.8 volts instead of 168 volts for example.
Just a thought, Jim.
