Originally Posted by JimIsbell
Are the thremistors attached to the stick directly or are they inside the stick? Can the stick be pulled out of the stack with the junction board (the one with components on it, not the orange one, I differentiate because the orange boards are also connectors) to the left without disconnecting the thermistor, by just disconnecting the PTC Strip and the end bolt. So far in replacing sticks I havent had one that couldnt be taken out that way so I assume that I havent removed one with a thermistor attached....OR....the thermistor is NOT attached...OR....it detaches without much effort when the stick is pulled.
They are taped to the stick and another layer of shrink is over them. You have to take them out from the side with the wire or you'll damage them. Just transplant the thermistors to the new sticks with scotch tape.
