pulling the injectors is pretty easy compared to cleaning the EGR plate.
here is how i did it:
remove the engine plastic cover. (3 10mm bolts)
Unplug injector connectors.
Remove 2 (10mm) bolts holding the injector wire holder plastic.
Remove 2 (10mm) bolts holding down the fuel rail, and just pull up.
Take out injectors.
Oh and according to the manual, you are supposed to relieve fuel pressure also, which is done by turning the big nut on the far left side of the fuel rail and hold a rag around it.
and when installing them back in, make sure the injector gaskets/rubber rings dont get pinched.
